NI TestStand
Access Teststand Run Mode Programmatically
I would like to access a Sequence Run Mode programmatically during my test.  I would like to check if the test is selected to be skipped in the pre-expression and set a local flag based the result.
I will use this flag to run a later step or a sub sequence.
Is there a way of doing that?
(1,504 Views)
Run Mode is at the step level:
Locals.MyFlag = Step.GetRunModeEx() == "Skip"
https://www.ni.com/docs/en-US/bundle/teststand/page/tsapiref/reftopics/step_getrunmodeex_m.htm
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,442 Views)
