NI TestStand
Access elements of an array passed as Object Reference
If you have access to the assembley.
It is possible to use system.double[] instead system.array[]
If yes TS directly writes into a numeric array.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 11 of 16
(2,971 Views)
Hi.
Just take a look at this stuff, added to NI-Example Comupter
Regards
juergen
--Signature--
Message 12 of 16
(2,970 Views)
I reallty appreciate you help !
I understand that example.
I stiil need to comprehend how to get hold the properties of an array of objects.
My source code is attached.
I "call" class.test(.....) from TestStand, and get an reference to "PP" back (array of objects containing 2 properties (frequency and signallevel).
"PP":
[0]
Frequency = 12345
Signal = 123465
[1]
Frequency = 12345
Signal = 123465
Message 13 of 16
(2,962 Views)
at the  moment i had no time to analyse your code
BTW. I have updated my example to system.array
Enjoy
Juergen
--Signature--
Message 14 of 16
(2,951 Views)
 i have updated my example to your Class Peak.
the sequence file shows how to access the properties of Peak.
regards
Juergen
--Signature--
Message 15 of 16
(2,933 Views)
Hi j_dodek
thank you so much for your help.
It's working now.... super cool.
br
Nikolaj
Message 16 of 16
(2,903 Views)
