NI TestStand
Access sequence file requirements through TestStand API (C#/.NET)
How can I access the requirements in a sequence file's properties through the TestStand API?
In C#, I can get the version and comment fields easily:
seqFile.AsPropertyObjectFile().Version;
seqFile.AsPropertyObjectFile().Comment;
But I can't figure out how to get the requirements. I think this gives an array of strings with the requirements:
seqFile.AsPropertyObjectFile().Requirements.GetNthSubProperty("", 0, 0).GetPropertyObjectElements("", 0)
But then I run into problems using it as it is an array of PropertyObjects instead of strings so I get exceptions about expecting an array of containers and finding an array of strings.
(2,203 Views)
Accepted by topic author cjohnson963
I feel silly with how quickly I figured this out after posting the question. I only recently figured out how to navigate the help on TestStand in order to understand and follow the API.
https://zone.ni.com/reference/en-XX/help/370052W-01/tsapiref/reftopics/propertyobjectfile_requiremen...
This page shows how to access the requirements. I was close.
(2,196 Views)
