NI TestStand
Accessing Clipboard Terminates TestStand
I'm running TestStand 2010 Fix 1 on a Windows 7 64 bit machine. I create a new Statement step and when I try to copy/paste text from Notepad TestStand terminates abruptly.
Has anyone seen this problem?
Edit1: I just tested with Label and MessagePopup steps and things work fine but as soon as I try the Expression step TS dies
Please help!
<<- N ->>
(3,424 Views)
More info: I repaired the install and the problem persists. I am able to copy/paste text that does not contain dots, but when I include expressions like "Locals.Variable" things break even copying from a different TestStand step
Is this a known issue?
(3,419 Views)
N -
Please provide the following information regarding your operating system and settings:
1. What exact version of Windows 7 are you running? Standard/Professional/Ultimate?
2. Do you have a service pack installed? Windows 7 SP1?
3. Is this an English OS? Are your regional settings default?
4. Finally, do you have Windows Tablet PC Components enabled? Could you try disabling them and let us know if this changes anything?
Please provide the requested information as I would really like to determine the cause of this problem and whether or not it will affect multiple users.
Manooch H.
(3,392 Views)
Hi Manooch,
These are the details:
1. What exact version of Windows 7 are you running? Standard/Professional/Ultimate? Enterprise
2. Do you have a service pack installed? Windows 7 SP1? No
3. Is this an English OS? Are your regional settings default? English and default, no other languages are supported
4. Finally, do you have Windows Tablet PC Components enabled? Could you try disabling them and let us know if this changes anything? Tablet pc components are unchecked
I ended up uninstalling TestStand and reinstalling and things are working now,
Thanks for checking!
<<- N ->>
(3,357 Views)
