NI TestStand
Accessing LabVIEW class properties
Hi everyone,
is it possible to access a LabView class property directly in a TestStand Expression?
F.e. I have a Timer.class in Labview from wich I read a status with a Property Node Call:
Can I somehow access it like a Container  "Locals.TimerClass.T_UsermenuTimeout" ?
Thank you for any ideas
(1,372 Views)
No.  That would violate the encapsulation principle of objects.  You need to call a method of the object in order to get private data out.
(1,358 Views)
ok, calling a method would be fine, too. But I guess I can't call a LabView method in an expression either?
(1,352 Views)
