NI TestStand
Accessing Object Reference from C#
I am developing a script that shows FileGlobals variable inside a small C# interface, a sort of debugging view to keep track of a couple of variable while testing units.
I managed to display an Array of number that shows as is in TestStand:
The corresponding C# script is as follow (ObjectList is in FileGlobals):
private NationalInstruments.TestStand.Interop.API.SequenceContext mSequenceContext;
this.objList=this.mSequenceContext.FileGlobals.GetPropertyObject("ObjectList",0);
double[] myArray = (double[])this.objList.GetValVariant("", 0);
this.testLabel2.Text = myArray[0].ToString() + " " + myArray[1].ToString();
In the label I can read "1 5", great success !
Now I want to reproduce the same thing but with an Array of Object References, here seen in TestStand:
Should I also start with this.mSequenceContext.FileGlobals.GetPropertyObject ? Does this work as a general approach to retrieve any object?
I'm a bit lost when it comes to what to do after that, any help much appreciated.
(4,171 Views)
If you look at the API for property objects there are a whole bunch of GetValXXX and SetValXXX methods.  https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/propertyobject/
Some of them say GetValxxxByOffset.  These are used to index arrays.  In your case you could do:
this.obj = this.mSequenceContext.FileGlobals.GetValIDispatchByOffset()
https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/propertyobject_getvalidispat...
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,167 Views)
Right ok, I think I got to that point some other way but this.obj is just a C # object and I could not find a way to retrieve the value of what it was pointing to.
(4,150 Views)
Got it ! To display first element:
this.objList2 = this.mSequenceContext.FileGlobals.GetPropertyObject("ObjectList2", 0);
private NationalInstruments.TestStand.Interop.API.PropertyObject t;
dynamic[] v = this.objList2.GetValVariant("", 0);
this.t = (NationalInstruments.TestStand.Interop.API.PropertyObject)v[0];
t.GetValNumber("", 0).ToString(); // here is the value !
(4,113 Views)
