NI TestStand
Accessing Step's Limits Settings In .NET
I'm able to parse the following step's Limits properties:
- High:  [Step].AsPropertyObject.GetValNumber("Limits.Low", 0).ToString()
- Low:   [Step].AsPropertyObject.GetValNumber("Limits.Low", 0).ToString()
- Comparision Type:  [Step].AsPropertyObject().GetValString("Comp", 0)
Does anyone know what property to parse for the Units (ie degrees, rpm, mL, mm, etc..)?
TIA for your help.
(3,628 Views)
The units are under the results.units
If you are using TS 2010 or above you can click on the step -(properties tab)- go to property browser and looks for the step.variables to know where they are.
(3,620 Views)
I found it: [Step].AsPropertyObject().GetValString("Result.Units", 0)
(3,608 Views)
