NI TestStand
Accessing individual units' report text from within batch model
Under the sequential model in the PreUUT callback, I can access the text report in RunState.Report.All.
In the batch model, that same variable in PreBatch just gets me the batch report text. How can I get the individual unit report text? Thanks.
(2,544 Views)
Have you tried using the PreUUT callback? In the batch model, the PreUUT callback is used at the beginning of each socket.
(2,503 Views)
Thanks for the suggestion.
There is one issue: the PreBatch runs before the PreUUT. So in order to see the results of the individuals in the current batch, I have to enter the next batch information first.
Can I force PreUUT to execute before PreBatch somehow?
(2,498 Views)
Accepted by topic author stephenb2
Thanks shrupa123 for putting me on the right path.
It turns out that what I wanted was the PostUUT callback. First the PreBatch is executed, then the main sequence, and finally the individual UUT reports are accessible in the PostUUT.
(2,492 Views)
