NI TestStand
Action not on Result sheet
I inserted an Action Step to my TestStand routine but when the test has finished, it does not appear on the result sheet as DONE. All the other tests appear on the result sheet (Pass/Fail tests, Numeric tests, etc) but not the Action Steps. This used to work, so I have clearly changed something and this also works on another PC (same set-up).
Does anyone have any ideas why this is now missing?
Regards
Chris
(2,925 Views)
Hi all,
I have fixed it now. I clicked the box that said restore to defaults (in result processing) and it now shows the Action Step in the results
(2,901 Views)
Check with Result processing Settings, also try to check the difference between the two PC's on result processing
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,900 Views)
