NI TestStand
Activation Teststand (evaluation)
I have downloaded teststand for evaluation, but when I run "Install licens files" at the License Manager a pop up window tells me: "The requested operation requires write access to the license directory". I am administrator, but when I have installed other programs I often get a popup window: "you have not permission ... " , but after a second win7 complete the operation.
Niels Krabbe
(3,656 Views)
Hi Niels,
Which version of TestStand are you trying to activate?
Have you tried running NI License Manager as administrator? (Right-clock and choose Run as Administrator)
Eirikur Runarsson
(3,627 Views)
Hi Niels,
Do you have any updates? Are you still seeing the same issue when activation TestStand?
Eirikur Runarsson
(3,591 Views)
