NI TestStand
ActiveX Adaptor "Attach to Active" option
I can't get the Attach To Active option to work in Test Stand 3.5 (I get the error - "Attach to Active Object" in automation call failed.
Operation unavailable)
The ActiveX component is registered in the ROT (I've tried various names) and I can retrive it using my own test component.
Would anyone have some sample code that makes use of this option that I could peruse?
Dave
(3,042 Views)
Never mind, problems solved - FYI the name in the ROT must be the coclass guid.
(3,039 Views)
