NI TestStand
ActiveX Automation Error -2147023706
Im running Teststand 2010 SP1 on Windows XP. I'm using a custom process model to print out the report. However I get an intermittent error related to ActiveX Automation. Error pop up attached. Is this an issue with Teststand or ActiveX.
Any help greatly appreciated.
(2,130 Views)
Hi Anatine,
I hope you have resolved this error now. However, if you haven't I would like to direct you to another post on the forums with the same error: Forums- ActiveX Automation Error When Printing Report. This discussion links you to an example which you can take a look at.
Please also ensure you are using a supported browser such as Internet Internet Explorer versions 6 to 8, Active X isn't supported on Microsoft Edge (See the attached table).
Do let me know if you have any questions.
Kind Regards,
Alice
(1,991 Views)
HI Aboughton,
This issue was resolved by reverting From Internet Explorer 8 to 6
(1,980 Views)
