NI TestStand
ActiveX Engine Question - LabVIEW Interface
I have a simple operator interface running from LabVIEW that accesses
the TestStand engine via ActiveX and runs a sequence file that contains
a number of subsequences.
What I want to be able to do is stop this sequence at any point and then
jump to a particular subsequence .
Then when I run the sequences again I want to be able to continue
through to the end of all the subsequences in the sequence file.
So far I have found how to stop the execution and to run a particular
sequence within the file but I can't get it to continue to the end (run
the other sequences).
If any one can point me in the right direction, I would greatly
appreciate it.
Rob Kennedy
r_kenned@ihug.com.au
[See first answer for additional info
rmation]
(3,927 Views)
[Attachment(s) for question]
(3,927 Views)
