NI TestStand
ActiveX error -143 with modified Operator Interface
Don't know if this is a CVI question or a TestStand one. I've modified the operator interface and it executes fine on most PC's.
On one PC however, it executes correctly in its build directory, but if it is moved to another directory, (The directory where it will be finally installed to) the main panel load function fails right at the start of the execution, giving an ActiveX error -143.
All the PC's have TestStand 3.1f1 and CVI 7.1.1 installed. The problem seems to have been noticable on that PC after the code was compiled with 7.1.1. The original (unmodified) Test Executive works O.K. wherever we put it.
This isn't the first time I've had an ActiveX type error with CVI & TestStand, I've posted another message on the CVI message area, detailing another unresolved problem giving the same ActiveX error code (Using the 3D Graph control.) This problem exists on ALL machines.
Also, what is ActiveX error -143?!
Brian
(3,373 Views)
  hopefully the issue is covered in this thread :
I can't see why different directories would cause it to work / not work though.
Sacha.
// it takes almost no time to rate an answer Smiley Wink
(3,144 Views)
