NI TestStand
Activex and .net Labview Teststand
Hello
I had a problem when i use a .net assembly in teststand
  • I created a VI and in this vi i use "this.context" activex for receive the teststand context
    • When i use the VI in teststand everitging work
  • Now I built a assembly .net from the VI
  • The assembly doesn't work
  • Teststand message error "Object of type 'System.__ComObject' cannot be converted to type 'NationalInstruments.LabVIEW.Refnums.LVBaseRefnum"
I think activeX doesnt work in .net assembly
How i suppose to fix this issue ?
Thanks you
(2,299 Views)
Hello Lunik,
If i understood correctly, you created a LabVIEW VI in which you use ActiveX.
When trying to call a .NET assembly in this VI, it doesn't work anymore.
My first question would be: do you know that you can call .NET assemblies directly in TestStand?
If yes, what is the result?
Have a nice day!
Armando
(2,271 Views)
Hi folks,
I have exaclty the same issue.
I have a LV library which needs "SequenceContext" object as input parameter
I need to call the library from C#. So I'm creating a LV DLL for .NET.
Application build generate a .NET function with LVBaseRefnum as parameter.
How can I convert SequenceContext object into LVBaseRefnum?
Thanks for your help
(2,157 Views)
