NI TestStand
Add PDF report type to TestStand
We have created a PDF report generation method.  We would like add "pdf" as a selection in the TestStand report options editor screen.  Has anyone else added a new report generation method to TestStand?  Will we have to modify the support model dll to make this appear as a selection in the report editor screen?
(3,165 Views)
Hello CS,
You are right on track with your identification of modelsupport2.dll as the code module that is responsible for the Report Options dialog.  This dll is located in the following directory:
<TestStand>\Components\Models\TestStandModels\
I am not sure whether you will be able to just modify a parameter that is passed in the particular step that calls this code module or whether you will need to modify the dll itself.  I would be glad to look into the issue further.
(3,128 Views)
