NI TestStand
Add a substep (Edit Mode) with LabVIEW
My supplier has delivered a library of steps in TestStand (with a TypePalette and associated Ini Files).
I'd like to custom the INI file with LabVIEW to add a module as "Edit Substeps" on the differents Steps Types.
With "GetTypePaletteFileList" and "PropertyObjectFile", I can see the differents Type Palettes and the associated paths but I can modify it (add a substep module ... etc) ?
Is it possible ? Someone has an idea ?
Thank you for your help
YR42
(3,030 Views)
Here you can find a post, with an example:
 http://forums.ni.com/ni/board/message?board.id=330&requireLogin=False&thread.id=5599
I hope that this link will help.
Regards
Nacer M. | Certified LabVIEW Architecte
(2,974 Views)
