NI TestStand
Add button to LV OI
Hi, I need to add a TestStand UI button control to labview OI. Pressing the button, it should generate an event into the main event loop.
I cannot generate the event from a TestStand ui button control.
Thanks a lot
(3,643 Views)
HI logatto,
You should try this method: Create a LV button, then in the event, wire the TS UI button reference to a DoClick Method.
Hope this helps
Rodéric L
Certified LabVIEW Architect
(3,626 Views)
Hi, I use dthe DoClick method but this is to generate a click programmately. The user must generate the asyncronous event, but I cannot connet it to the event structure.
(3,623 Views)
If you want to handle the button click with the event structure, I would recommend using a LabVIEW system button control rather than the TestStand button.  The TestStand buttons are better when used with a manager control using a connect method (see the simple OI example that ships with TestStand to see this implemented - <TestStand>\UserInterfaces\Simple\LabVIEW\TestExec.llb).
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,608 Views)
Yes I know, the probles is that the style is different. If there is no solutiono will repalce all the TestStand buttons with Labview buttons.
Thanks.
(3,591 Views)
You should, as Al already suggested, use a LabVIEW Button Control from the system palette, not the modern palette. The buttons in the system palette will look like the TS ActiveX button controls.
If the button should be used to interact with TestStand, i would never use a LV button for this. You would overly complicate the code because of this but getting nothing out of this.....
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,584 Views)
