NI TestStand
Add elements of variable containers with Teststand API
hello everyone
I use TestStand to call veristad for data acquisition, and use LabVIEW to call TestStand API function to generate test sequence. In the circle drawing step, I click the plus sign variable container to automatically add a group of variables.like VariableName,VariableUnit......;I want to know how to add elements of variable containers with TestStand API functions.
If you have any way for me how to do this, i will be grateful to you.
(3,379 Views)
Accepted by topic author OTGZzz
Basically you want to use the property object methods.  Depending on the variable type it will be different.
For example:
Step.SetValString("MyVariable", 0x1, "Foo")
Will create a variable called MyVariable for your step (if it doesn't exist) and set the value to Foo.  It will be a string variable.
You can read more about the SetValXXX  methods for the property object here: https://zone.ni.com/reference/en-XX/help/370052AA-01/tsapiref/reftopics/propertyobject/
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,298 Views)
Thank you. That's what I want
(3,284 Views)
