NI TestStand
Add seconds to a timestamp in a string.
Hello all,
I would like to add seconds to a timestamp in a string.
For example,
"2022/10/21 09:55:03.734" +2.5s = "2022/10/21 09:55:06.234"
"2022/10/21 09:55:03.734" +305.6s = "2022/10/21 10:00:09.334"
In C# programming, it would be super easy since I could parse the string as a DateTime object and then use the "addseconds" function.
Are there any functions (I didn't find any) which could help to make it easy in TestStand?
Or have I no other possibilities than coding this logic myself? Which is of course possible but a bit messy.
Ludovic
(1,672 Views)
Dear Lchar,
There is no such function in testand, however you can convert your time to number add the seconds and then convert back. Here's a forum post for converting time to number https://forums.ni.com/t5/NI-TestStand/Calculate-with-timestamps-in-string-format/td-p/231843.
best,
anasei.
(1,518 Views)
You can use C# as well. DateTime object methods are at your fingertips.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,505 Views)
