NI TestStand
Add step module time in report document
Hi All,
I use sequence editor TS 2013
How can I add the module time value of the step on the report jdocument?
Tnx,
Message 1 of 8
(5,954 Views)
In the report options, check the option "Include Execution Times".
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(5,953 Views)
Hi Norbert,
The execution times checkbox is marked and has no effect on step module time.
I think it related to the total execution time of the sequence and doesn't for the module time of the step.
The report shows me only :step name,status,measurment,units,limits and comparison type.
Tnx,
Message 3 of 8
(5,949 Views)
There is only a valid time if the step includes a code module written in an external language. There won't be numbers in steps using pure TS functionality (e.g. statements).
Please tell us what kind of step you are using and post an image of the report. Also you should describe/post image of your report settings.
You didn't modify the report plug-in, did you?
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(5,942 Views)
Execution time is displayed for all report formats except when using horizontal stylesheet in XML and ATML report. If you want to see execution time in XML or ATML reports, change the stylesheet.
What report format are you trying to create?
Did you try with other stylesheets and other report formats?
- Shashidhar
Message 5 of 8
(5,935 Views)
Hi Norbert,
Please find attached file
Hope it understandable,
Tnx
Message 6 of 8
(5,931 Views)
The snapshots inside your attachment specifies that you are using ATML5 report with tr5_horizontal.xsl stylesheet.
Modify the stylesheet to tr5_report.xsl or tr5_expand.xsl to view the execution time in report.
- Shashidhar
Message 7 of 8
(5,928 Views)
Hi Shashidhar,
it works fine,
thank you
Message 8 of 8
(5,925 Views)
