NI TestStand
Add to NI_UserCustomPrivileges using API
I've searched in several ways for this information and have been unsuccessful.  Is there a way to add entries to the NI_UserCustomPrivileges container--and save the changes to disk, of course?  I've found many examples of adding and deleting users and changing their privileges, but I haven't been able to find a way to add new privilege variables.
Thanks for your help!
(3,633 Views)
Accepted by topic author strimble
Hi strimble,
Assume we create two local variables, an array of Object References called "typeFileArray", and a Number called "typeIndex". Then, the following should allow you to create the type of variable you are interested in.
Locals.typeFileArray =
RunState.Engine.GetTypeUsageLocations("NI_UserCustomPrivileges"),
Locals.typeIndex = Locals.typeFileArray[0].AsPropertyObjectFile.TypeUsageList
.GetTypeIndex("NI_UserCustomPrivileges"),
.GetTypeDefinition(Locals.typeIndex).SetValBoolean("HelloJohn", 1, True),
Locals.typeFileArray[0].AsPropertyObjectFile.IncChangeCount(),
Locals.typeFileArray[0].AsPropertyObjectFile.SaveFileIfModified(True)
I hope this helps!
John M
(3,605 Views)
Thanks, John.  This works perfectly.  I didn't realize it would be so simple.  Thanks for your help!
(3,600 Views)
