NI TestStand
Adding images to the teststand report
I have seen the other description of how to add a report to teststand, shown below,
Step.Result.ReportText = My Picture
but I want to be able to add many different images from many different file locations specified as FileGlobals.Image1.
How do you combine the HTML with the Teststand statement. I imagine it is something like this below, but this doesn't work.
Step.Result.ReportText = "Field of View Image"
(5,195 Views)
Hi ADL,
Your expression should be :-
Step.Result.ReportText = "Field of View Image""
StationGlobals.LastImagePath will contain the full pathname to the file or relative pathname.
e.g StationGlobals.LastImagePath = "c:\temp\myimage.gif" or
StationGlobals.LastImagePath = "myimage.gif"
Regards
Ray Farmer
Regards
Ray Farmer
(5,195 Views)
Ray,
Thanks for the reply, but you have 7 sets of quotes in the expression.
I copied the text in directly and teststand gives an "Unexpected Token: Field" error when checking the syntax.
(5,195 Views)
sorry about that,
I have attached an example
Regards
Ray Farmer
Regards
Ray Farmer
(5,195 Views)
Thanks Ray that worked a treat.
(5,195 Views)
