NI TestStand
Adding report header lines using expand.xsl style sheet
Hello
I would like to add a few header lines (appears only at the first page of the report) into my XML report that is based on expand.xsl style sheet.
Since I am not familiar with XML, is there any example or a modified (ready to run) expand.xsl style sheet that implements it?
Thank you
Zvika
(3,239 Views)
Hey Zvika,
Chek out this website:  http://zone.ni.com/devzone/cda/epd/p/id/4759
NI doesn't support any changes in the xsl however so if you change it you are on your own.  You can look to this website for help with that: http://www.w3.org/XML/
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,226 Views)
