NI TestStand
Additional Results Step: Log Number As Hex In Report
I am trying to use the Additional Results teststand step to log an Array element (which is a cluster of numeric values) after it is iterated through a for loop. The problem is that I want the value to be displayed as in HEX format not decimal. So instead of logging "2015" in the report I want it to log "0x7DF" Instead. See my current step settings below:
Any idea how to force the step to log these numeric values in hex format?
(3,529 Views)
Try right clicking on the local variable field, select Numeric Format, and choose hex.  That worked to get the hex format into the report for me in a simple test case.
(3,499 Views)
I have tried that and it doesnt seem to have any impact on the logged result in this case. Also how would this work in a case where the local is an array with an "empty" bounds? My point is I don't think that is a very flexible solution unfortunately.
(3,493 Views)
I'm not sure about the details of your sequence, but I've attached a sequence that logs locals.a, which appears in the report as decimal. It also logs locals.hexformat = locals.a, which logs the same value but it appears in the report as hex.
(3,432 Views)
You can try
str(variableName, "%x")
Best Regards
Sumit Memane
CLAD, CTD
(1,580 Views)
