NI TestStand
Additional data in ModelData.Testsockets[0].UUT
I'd like to store additional data in the UUT. I have created the variable called Reference but It seems that I need to create a new UUT (Container) Type and replace it in the array. How can I do that? Shall I create a whole new model?
Parameters.ModelData.TestSockets[Float64(Locals.CurrUUTData.Slot)].UUT.AdditionalData.Reference = Locals.currUUTReference.
gives
The post-expression for the step 'Statement' could not be evaluated.
Unknown variable or property name 'Parameters.ModelData.TestSockets[Float64(Locals.CurrUUTData.Slot)].UUT.AdditionalData.Reference'.
currUUTReference is reference to the UUTClass object.
(3,149 Views)
I can see that you're trying to include some additional UUT information in your test report, however I'm not familiar with your approach.
There is information about customizing your report here
          -  The section titled 'Logging additional UUT and Station data to the report header' should be helpful here.
There is also a similar forum post here
          -  Although the original questions mentions a database, the solution works for result collection and therefore will function the same for generating a report.
Hopefully these resources point you in the right direction!
(3,107 Views)
Accepted by topic author Heartbeat
I was able to store additional data using this procedure:
Parameters.ModelData.TestSockets[CurrentSlot].UUT.AdditionalData.NewSubProperty("Foo", PropValType_Reference, False,"",0),
Parameters.ModelData.TestSockets[CurrentSlot].UUT.AdditionalData.Reference = Locals.FooReference
Or
Parameters.ModelData.TestSockets[CurrentSlot].UUT.AdditionalData.SetValString("key",1,"value")
(3,102 Views)
