NI TestStand
Advanced property flags for variables
I am running the batch mode and needed to share local variables between threads. I ended up using station globals. I found an advanced property flag "PropsFlags_Shared". This appears to work. There are other advanced flags which are accessible from the advanced button under properties for locals. I am using TestStand 2.0. I notice that there were even move propertied for TestStand 3.0.
My Question is there a list of Properties and there description of what occurs when they are set?
(3,217 Views)
The properties you are referring to are listed in the TestStand Online Help. To access the help file simply choose Start>>Programs>>National Instruments>>TestStand>>Online Help>>TestStand Help. Then click on the Index tab of the help dialog. Type in PropertyFlags and you will be able to see a listing and explaination of all the properties.
Ryan
(3,217 Views)
