NI TestStand
After Specific Step Fails Exit Test UUTs Loop
Hi everyone, I am testing using the TestUUTs method.  After a "specific" Main Sequence step fails I want the step to say "FAILED" and I want the Test Executive to "EXIT TEST" so that the "ENTER UUT SERIAL NUMBER" message box does not come up.  Basically, I want to shut down the "TestUUTs" loop.
Is there a Runtime.Engine call or another way to do this in TestStand?
Thanks so much!
(4,733 Views)
Here's one method.  Let me know what you think.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,721 Views)
Thanks Jiggawax for the quick reply.  I have TestStand 2013 so I cannot open the file you attached since it is in TestStand 2014.  Can you resave the file as 2013 and re-attach?
Thanks!
(4,693 Views)
See if this works.
jigg
CTA, CLA
testeract.com
(4,690 Views)
