NI TestStand
An error occured accessing the LabVIEW ActiveX automation server. Error code -18001
I am attempting to deploy a TestStand sequence that works perfectly fine on my development machine but when launching it on the deployment PC, I get the attached error.
I reverted both TestStand sequence, and dependent Labview VI's to 2019 runtime as our company's TestStand executive GUI is built under that version of Labview and TestStand.
Attached is the error code when trying to run the sequence.
Message 1 of 1
(767 Views)
