NI TestStand
An error occured evaluating the database logging Result Filter Expression
During the course of our investigation, we discovered that a problem was introduced into the Database Logger in TestStand 4.1.  TestStand 4.0 schemas should work perfectly in TestStand 4.1 when this is fixed. We appologize for the oversight and are working to correct it as soon as possible.
Please contact an engineer directly if you would like more information.  When a fix is available I will post on this thread.
Josh W.
Certified TestStand Architect
Formerly blue
Message 21 of 26
(1,772 Views)
Hello Tom and Hans,
I just wanted to reiterate what Josh mentioned, which is once we have a fix your old schemas will work. Because of this I would recommend waiting to use those rather than customizing new ones. If you do have an immediate need to customize a new schema though let me know and I will assist as much as possible.
With warm regards,
David D.
Message 22 of 26
(1,766 Views)
Hi Dr Doiron,
I've also found if I set the database options to save all results, the error doesn't seem to reoccur. The downside is our database is growing in size rapidly.
Tom
Message 23 of 26
(1,755 Views)
Josh,
Thanks for the response on this.  I'd be happy to test any changes if needed, just email them to me.
Dave
Message 24 of 26
(1,720 Views)
Hi everyone,
Has there been any resolution to this problem? I'm commissioning a new production line next week and urgently require database logging in this project.
Alternatively, does the fix copying the TS4.0 database sequence work robustly as fix?
Tom
Message 25 of 26
(1,693 Views)
We have created a Patch for TestStand 4.1 to fix this isue with the Database Logging Result Filter Expression.
You can find the patch here: TestStand Development System 4.1 - Windows 2000/Vista x64/Vista x86/XP - Patch 123594: Fix for Datab...
This patch should fix all of the issues described in this forum thread.  If it does not, please let me know.
Josh W.
Formerly blue
Message 26 of 26
(1,686 Views)
