NI TestStand
Announcing TestStand 2021 SP1
TestStand 2021 SP1 is out now and available for download!
The exciting release of TestStand 2021 SP1 includes stepping into Python code from TestStand directly into Visual Studio Code among other improvements.
Key updates include:
Enhanced Python Module Debugging
Step into your Python code from TestStand with Visual Studio Code.
Support for HMTL Reports in Modern Browsers
You can now view TestStand default reports with modern browsers. Microsoft Internet Explorer dependency to view TestStand reports has been removed.
Improved Error Reporting
When possible, TestStand indicates where in the sequence file the error occurred. Also, the error dialog box displays the cause and possible resolutions for the error.
Updates to Input and Output Stream Parameter Capabilities for Sweep Loop settings
You can now import parameters from and export parameters to CSV files.
Test vector table is out-of-sync when changes are made to dynamic parameters
Enable and Disable Values in the Values Table for Sweep Loop
For Static Arrays, enable and disable individual values in the Values table located in the Step Settings. These changes will be reflected in the Test Vector and Value Summary tables
For additional information view the ReadMe.
Message 1 of 1
(2,365 Views)
