NI TestStand
Any Good Way To Print A Sequence?
I'm currently designing a test system and I've got some failrly involved sequences that I need to validate with the device designer. I need to verify that each step has all of the proper parameter values, the steps that do pre/post processing are properly setting and using local variables, etc.
This is the kind of thing I like to do on paper, not on a screen. On paper I can make notes, draw lines, mark where I left off, doodle, whatever. In addition I can sit down at a desk with another engineer and we can share the same printout as we pour over it to make certain everything is correct.
I may be blind, but I just don't see any way to print out a test stand sequence. Do I need new glasses? More coffee?
..glen
(3,081 Views)
http://zone.ni.com/devzone/cda/tut/p/id/4276
Hope that helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,073 Views)
