NI TestStand
Any Resources for Learning Object Reference in TestStand?
Hi All,
I have been using Active X servers in TestStand for several years and now some of the newer stuff I am being supplied with is Dot Net objects. Does anyone know of somewhere to learn the correct way to use object references in TestStand. I don't understand when you should create a new object  vs just using an existing object reference. I also would like to understand how to use an object reference variable.
I looked at the TS examples, but there is not an explanation.
Any ideas?
TIA,
Jim
(3,344 Views)
Jim,
You may try reading through the NI TestStand Advanced Architecture Series, specifically Chapter 2: Using the NI TestStand Object Model. These may shed some light on the issue.
Steven Zittrower
(3,324 Views)
Thanks Steve!! It was an excellent article, but my search is for Dot Net Object References. The TestStand Object Model is an ActiveX server.
Thanks Again,
James
(3,312 Views)
James,
You are correct that we don't have very many specific examples. The best would be the Demo example <TestStand>\Examples\Demo\DotNet. Basically, you're individual .dll, file, or reference would dictate the best practices needed to take to interface with it.
Steven Zittrower
http://www.ni.com/support
(3,288 Views)
