NI TestStand
Append 1d array to 1d array
Hi All,
I wonder if there is a way to append 1D array to another 1D array in TestStand other than by copying element by element in a loop?
Also if a part of array, say, Array_1 which has 10 element need its elements from 5 to 10 to be appended to another array at the bottom. currently I use loop. But I wonder other than looping each element of the array to another array is there any standard functions or TS APIs available like in LabVIEW?
JKV
(6,617 Views)
SetNumElements(Locals.Sum, (GetNumElements(Locals.Array1) + GetNumElements(Locals.Array2))), //Allocate Array For Sum
Locals.Sum = Locals.Array1 + Locals.Array2
It worked for me.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(6,609 Views)
Actually you don't even need the first line.  It still works.
To get a subset of an array you can copy the array over to a temporary array and then use the RemoveElements() function to remove the parts you don't want.  Then add that temporary array to your other array.
Hope this helps,
jigg
CTA, CLA
testeract.com
(6,608 Views)
@JKV999 wrote:
Hi All,
JKV
For the second question, in newer versions of TestStand (I think this feature was added in 2012), you can do the following:
Locals.newArray += Locals.Array_1[5..9] // NOTE: assuming array is 0-based so has elements 0-9
-Doug
(6,605 Views)
Hi Doug,
that is a nice feature.
Thanks for pointing out.
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(6,587 Views)
