NI TestStand
ApplicationMgr sequence file reloaded
 Hi all,
I'm developing an OI in # with ApplicationMgr object.
I see QueryReloadSequenceFileEvent, it's working and fired when I change a file in SeqEdit.
But I would like to be notifiy by an event when the sequence file has been reloaded.
I don't see any event for that.
Thanks in advance for your help
Message 1 of 14
(1,853 Views)
Could You please explain what "OI in # " means?
As a suggestion for now , check this link, it might  give You some ideas.
Regards.
Message 2 of 14
(1,814 Views)
Sorry for the mistake. I mean "Operator interface in C# language"
Thanks for your help
Message 3 of 14
(1,810 Views)
No problem. So as I understood You just need a popup window created.
Here You can find link for it in C#, and here for LabVIEW.
Regards.
Message 4 of 14
(1,800 Views)
Thanks for your help. But I don't need a popup windows.
I need to be notified when the sequence file has been reloaded when it has been modified by another application.
Message 5 of 14
(1,793 Views)
So can You describe what kind of notification You want to receive?
Regards.
Message 6 of 14
(1,785 Views)
When I modify a sequence file out of OI, the event QueryReloadSequenceFileEvent is raised.
This event is raised just before sequence file reloading.
Does it exist an event raised after the sequence file reloading.
I hope I'm clear.
Message 7 of 14
(1,781 Views)
Okay, check this link, I think it's what You are looking for.
Especially check this one: PostMainSequence.  Even though this are for Batch of Sequences, but I guess it might work for one sequence.
Regards.
Message 8 of 14
(1,756 Views)
Thanks for your reply.
But I 'm speaking about Operator interface in C# (.NET) and I'm looking for an event on OI side, not on sequence side.
Message 9 of 14
(1,751 Views)
For better understand, could You please send Your "Operator interface" screenshot ?
Regards.
Message 10 of 14
(1,748 Views)
