NI TestStand
Approach to report customisation: LaTeX
I'm wondering what approach would be the best in order to generate the TS report as .tex (test) file, to be easily digest by LaTeX compiler later on?
Shall I start with modification of the ASCII Text File report in Result Processing... window?
K.
(2,765 Views)
I'm not familiar with .tex format, but the example Text Report Plug-in may be a better starting point than the default generator:
<TestStand Public>\Examples\Customizing Result Processing\Model Plugin - Simple Text Report
Also a good resource:
Best Practices for NI TestStand Report Generation and Customization
https://www.linkedin.com/in/trentweaver
(2,744 Views)
