NI TestStand
Are nested Select steps allowed in TestStand?
I'm trying to nest one Select step inside of another.  Is this allowed?  I don't get any analysis errors but I do get the attached run-time error.  I've inspected my sequence and I don't see any errors.  I'm really just looking for confirmation that nested Selects are allowed - from there I can troubleshoot my code.
(3,023 Views)
Nesting Select-Statements is possible. I think you mixed up the "case"-section. Make sure that the setup is just as following:
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,996 Views)
