NI TestStand
Are not able to get the report option working
I have reinstalled Test Stand and after the reinstallation the report option will not work. Actually I got the problems after installing the patch "LV86f1RunTimePatch.exe" and "LVRTE86f1std.exe". Those two patches helped me when the Sequence was exstremely slow when uploading the VIs.
I have tried to reinstall Test Stand but it wont help. The report option will not appear under the configure tab and when I run my sequence the report tool want start.
How do I solve this?
(4,130 Views)
So there is no "Report Options" Entry in the menu which opens when you click an Configuration in the menu?
If you run you sequence, the Report Option dialog opens and what happens then?
Are you using a default process model? Are you talking about the NI Sequence Editor or a custom made UI?
Norbert
Norbert
Expert: Geometry
(4,099 Views)
There is no "Report Option" entry in the configuration menu.
No report option dialog appears when I run the sequence.
I am using the NI sequence Editor and I am not sure what you mean by process model but in the station setting something says that I use  the "SequentialModel.Seq"
(4,094 Views)
Is the Report Option not present at all or is it grayed out?
Norbert
[Edit] I understand that there is no entry at all. This leads to one suspicion: the installation on your computer is not properly working. The Report Option dialog is contained in the modelsupport2.dll. This dll is a very basic component for TestStand. I think that this dll has been corrupted by some ways... so i suggest you to do at least a repair install if not a complete reinstallation.
Message Edited by Norbert B on 11-13-2009 04:53 AM
Norbert
Expert: Geometry
(4,092 Views)
I have now done a complete reinstallation but still I don't have the entry to the report option dialog. Do you have some more ideas how fix this problem?
(4,060 Views)
Lets make sure that we eliminate the possibility of not having a process model selected (there are other ways to select the process model besides the station options).
With your sequence open what does the Model show in the status bar at the bottom?  See pic for example...
Message Edited by paulmw on 11-16-2009 10:15 AM
(4,055 Views)
Thank you! A process model was selected in the station option tab but in some way it was looking in the wrong directory. Now I pointed out the correct process model file and it works! As you understand Im a new user of test stand and Im very grateful for your help.
B0sse
(4,029 Views)
