NI TestStand
Are there any examples of queres or reports for the Access DB TS can generate?
I am currently useing the default TestStand SPC database storage routine to store the results of all runs. Are there any tools, queries, reports, etc. to help me post process this database? I thought I would check here before making something myself. Mainly looking for something that will do a scatter plot for a certian test so I can see where all the data is falling within the limits.
(3,107 Views)
Currently NI does not have any post processing tools to assist you in formating the result information specifically for TestStand databases. Obviously using LabVIEW or LW/CVI or some other programming language you could write your own program to do such post processing.
Scott Richardson - NI
Scott Richardson
https://testeract.com
(3,107 Views)
A company that makes SPC software designed specifically for TestStand is Vidaq. The product is called SPCStand. Their web sit is www.vidaq.com. I've only seen their brochure and brief demo so I can't say what are all of it's capabilities or limitations.
(3,107 Views)
