NI TestStand
Array of container shows different result in expression and runtime watchview
Hello gentlmen:
     Turning to you for container in array shows wrong result in runtime watchview in TS2013:
- I create a container array with number type and rename some components like below picture:
- Then i copy the created components to expression location  i want to use, no error checked out:
- But when starts to run, the 2 expression shows different result, one with name-->error, the other with index-->normal
of course I can use index one directly, but i think the named one is abnormal for user?
(2,353 Views)
Accepted by topic author johnnnywang
Sorry for any inconvenience, today when i try my sequence, all these 2 naming method becomes available!
What i done after defect is naming the value assign variables for these parameters same as parameters.
maybe the reason is "name should be keep same"~
that's all what i tried. FYI~
(2,325 Views)
