NI TestStand
Attaching the sequence files to .NET object and connecting to execution button of TestStand
Hi - I am fairly new to TestStand and I was wondering if anyone know how to solve my problems.
The scenarion is we have Test that has multiple Sequence. For example, Test1 has Sequence1, Sequence2 and Sequence3.
I am displaying the Test1 and its sequences in the .NET treeview. My question is, when I selected the sequence I want the AxSequenceView to display the selected sequence and same thing when I execute it from AxButton. I wonder if there is some overload/override function so I can connect the sequence to these TestStand objects.
Any ideas??
(4,064 Views)
You can view the source code for the C# Full-Featured TestStand OI to see how the axSequenceFileViewMgr is linking to the SequenceList.
This source code can be founf in the TestStand 4.1.1 installation directory location:
C:\Program Files\National Instruments\TestStand 4.1.1\UserInterfaces\Full-Featured\CSharp
Take a look at line 597 in MainForm.cs.
-Adri
Adri Kruger
LabVIEW Product Marketing
(4,040 Views)
Hi Adri K - The example is using TestStand objects. What I am trying to accomplish is, my sequence will come from the database and I can display that without any problem in .NET treeview. The thing that I am having hardtime is connecting the sequence to AxSequenceView object. From the example that comes with NI TestStand it is connecting the sequence by opening it through NIobject -which obviously is not what I am doing. Any ideas?
(4,026 Views)
Could you please provide the project that you are working with a description of what you currently have and what you would like to see. If you are not comfortable providing the project files please provide screenshots of the Designer and indicate in those images what you are currently experiencing and what behavior you would like to see.
-Adri K
Adri Kruger
(4,004 Views)
You connect a SequenceView to a SequenceFileViewMgr. Then when you set SequenceFileViewMgr.SequenceFile to be your file, all the SequenceFileViewMgr's connected controls, including the SequenceView, will display aspects of that file.
(4,002 Views)
I have made the following assumptions:
You know the path of the sequence file
You have already loaded the tree view elements
You can configure an afterSelect callback for the treeView control to have the follwoing functionality:
    //the sequence file that you are loading into the tree view
    public SequenceFile file;
        //this value will need to be the path of the sequence file
        public string path = @"C:\path_to_sequence_file\SequenceFile.seq";
        public Form1()
            InitializeComponent();
            axSequenceFileViewMgr1.ConnectSequenceView(axSequenceView1);
        private void afterSelectCallBack(object sender, TreeViewEventArgs e)
            if(treeView1.SelectedNode.Parent != null)
                file = axApplicationMgr1.GetEngine().GetSequenceFileEx(path,107, NationalInstruments.TestStand.Interop.API.TypeConflictHandlerTypes.ConflictHandler_UseGlobalType);
                axSequenceFileViewMgr1.SequenceFile = file;
                axSequenceFileViewMgr1.Sequence = file.GetSequenceByName(treeView1.SelectedNode.Text);
        private void formClose(object sender, FormClosedEventArgs e)
            axApplicationMgr1.GetEngine().ReleaseSequenceFileEx(file, 0);
-Adri K
Adri Kruger
(3,985 Views)
