NI TestStand
Bath of batch
In one test station, I need to test several UUTs simultaneously but each UUT has a different test code. For example, let's say we have these product types in the test batch: {A, A, B, C, C, C, A}
Each product type in the above set, shall run a it's own test execution and test code depending on the product number. {A.seq, B.seq, C.seq}
Until now I have tried the batch model, which creates a new test socket and test execution for each UUT. If I'm not wrong the code for all UUTs must be identical in the batch model.
I thought about experimenting  and perhaps create a new model (batch of batch model) but it seems way too complicated. What is a simpler approach to this problem? How can I have a batch test where each UUT loads it's own test code base on UUT.ProductNumber?
(2,490 Views)
Consider this simple example.  Let me know if you have any questions.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,454 Views)
