NI TestStand
Binary search using TestStand or LabVIEW
Hi there,
I need to find the gain of an operational amplifier. I have a functional test system using NI PXI and as software LabVIEW V8.5 and TestStand V4.0
How do I implement the following code in TestStand?
Perform a “binary search” type of procedure to find the limit of the input range, to a resolution of about 20mV.
For the differential amplifier positive signals (i.e. above 2.5V) the limits of the search range are +3V to +5V.
Go round the loop 7 times, each time round the loop halves the search range.
27 = 128 so starting with a 2V range the final result will be within about 2÷128 = 15.6mV of the true value.
See BinarySearch.xls for an example in excel of how the search works.
low = +3V
high = +5V
count = 7
do
            vpos  = (low + high) / 2
            vneg = vpos -1
            if output ok  then low = vpos
            else if output not ok then high = vpos
            count = count -1
while count > 0
output vpos
count = 7
For count = 1 to 7 #### either integer count or define step size =1
            vneg = vpos -1
            count = count -1
Next count
output vpos
I have started to implement in TestStand up to, please see attachment.
Any suggestion are very welcome.
Thank you for your time.
Marken
(3,440 Views)
I'd recommend doing this algorithm in LabVIEW as this is will be significantly slower in TestStand.
CTA, CLA, MTFBWY
(3,382 Views)
Hi Snowpunter,
Thanks for your replay.
I will try to do it in LaVIEW but I am not that skilled. So if I get stuck can I post the vi and maybe you can give me some hints?
Regards
Marken
(3,371 Views)
