NI TestStand
Blank screen appearing at the top left corner of NI Test Stand ,Icons(like "Run") are missing
A blank screen is appearing at the top left corner of the NI Test Stand so that all the icons(that includes "Run" button) at that side are missing.Restarting the system also didnt rectified the issue.Even reinstallation of NI Test Stand software also didnt solved the issue.Please provide a solution for this.
Please look into the attached screenshot showing the issue.
(2,495 Views)
Hi Jishnu,
It seems there has been some crash when you closed TS.
I would delete the files layout_current.bin and SeqEdit.xml , and check if this helps.
You find these in the following directory usually (Win10):
C:\Users\YOURUSER\AppData\Local\National Instruments\TestStand xx\
CsBihacker
(2,459 Views)
Hello ,
Thankyou for your reply.
Actually the "Call Stack" pane was crashed into that portion of NI Test Stand, which I understood when I ran one sequence.During run time, I could recover the top toolbar having "View" option.From there I selected "Reset UI Configuration".Now the problem is solved.
Thanks & Regards ,
Jishnu
(2,426 Views)
