NI TestStand
Break Point Enable/Disable in Teststand
Can any one please suggest where the Break Point Enable/Disable status variable will be stored in Test Stand. Will it get stored in any "ini" file or in any Test Stand run time variable.
In my Application I have to disable the break point option (Configure->Station Options->Execution->Enable Break Points) even though if its enabled in Test stand.
(3,835 Views)
Station option settings are stored in testexec.ini in the teststand config directory.
-Doug
(3,820 Views)
