NI TestStand
Build Error: The following file(s) could not be copied:
When trying to Deploy a TestStand System using version 4.0, I get the following error:
Finished Analysis
Building...
1:03 PM
An installer was not created due to an error
The build is finished
1:05 PM
Aborted
C:\Program Files\National Instruments\TestStand 4.0\Components\User\Utilities\PrimitiveFunctions\Search1DStringArray.seq
The sequence is under source code control however I have tried unlocking the file and still get the same error. I did notice the file had unsaved changes due to automatic conversions that TesStand performed when loading the file. However after saving the file I still get the same build error. Does anyone have any suggestions as to why this file cannot be copied?
I am also using Perforce P4V visual client as my source code control tool.
(2,975 Views)
(2,971 Views)
