NI TestStand
Building an Installer with TestStand 3.5 and LabVIEW 8.5
I am trying to build an installer with TestStand 3.5 and LabVIEW 8.5.
I can build an image but not the installer as I get a popup
"Insert the CD or browse to the location where the following component is located:
NI LabVIEW 8.5.
The last directory this component was found was:
D:\"
I insert the CD in D:\ and click OK. Shortly after that the same popup message appears. The only way to get out of this is too click cancel. This ends the intaller build process.
16:02
Making an installer, please wait...
Loading product deployment information
Adding files to installer
Done adding files
Preparing to build deployment
Copying products from distributions
Done building deployment
The installer is done.
The build is finished
16:32
Aborted
I have mass compiled all directories I use and Ni directories with LabVIEW 8.5
I have done a complete uninstall of all NI product and re-install.
The same error occurs.
TestStand and LabVIEW CD's are from NI Developer Suite Fourth Quarter - 2007.
Message 1 of 1
(3,756 Views)
