NI TestStand
C%23 Codemodule Debuging TestStand2013
I have focused that debugging is not working when i am trying to debug "old" codemodules in TS 5.1 (2013) which where build with VS2010SP1 using
.Net Framework lower/equal 3.5
By switching to TS5.0   OR  setting .Net Framework to 4.0 debugging is working.
Is there a workaround that allows debugging without modifications ?
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,019 Views)
Juergen,
You might be able to solve this by using an application configuration file. Here is a help file which describes this process: http://zone.ni.com/reference/en-XX/help/370052M-01/tsref/infotopics/net_clr/
I hope this helps, and let us know how it goes!
(5,013 Views)
Accepted by topic author j_dodek
All .NET code called by the .NET adapter in TestStand 2013 actually runs in the .NET 4.0 clr even if the assemblies were compiled as supporting .NET 3.5. So you should be able to debug your assemblies by setting the debugger to debug the .NET 4.0 clr. Newer versions of the .NET clr are generally highly backwards compatible with the old version. When a .NET 4.0 app loads a .NET 3.5 assembly that assembly is generally loaded into the .NET 4.0 clr so that it can be called from the .NET 4.0 code which the app is already running.
Hope this helps clarify things. To help you understand the difference between CLR version and framework version see the following:
a) .NET Frameworks 2.0, 3.0, and 3.5 all use the .NET 2.0 CLR. Assemblies compiled against these frameworks can generally also be loaded in the .NET 4.0 CLR (the one exception being C++/CLI assemblies which require an app config file setting to allow them to be loaded in the .NET 4.0 CLR).
b) .NET Frameworks 4.0, 4.5, and 4.5.1 all use the .NET 4.0 CLR.
c) There is only one of each CLR on a machine, so if you have .NET 3.5 installed on your machine you have a .NET 2.0 CLR installed which supports .NET 3.5. Similarly if you have .NET 4.5.1 installed on your machine, you have a .NET 4.0 CLR which supports 4.5.1. So basically .NET Framework 4.5.1 installs over and replaces .NET Framework 4.0.
I know it's a bit confusing. Let me know if you have any questions.
-Doug
(5,007 Views)
Hi Doug,
Thanks for clarifying.
Reagrds
Juergen
--Signature--
(4,955 Views)
