NI TestStand
C# .NET DLL REMOTE (ON CENTRAL SERVER) ERROR
I designed a DLL Library in C# .net framework 4.0 and made a sequence on teststand to use this library.
Everything works fine if I put the DLL locally to the PC running the sequence.
The problem comes here :
We have a centralized server that contains all DLLs related to the tests and they are loaded in memory from that server.
If I move this DLL anywhere on that server, and go into the tab to set the new path, it actually refuses it with a red-rounded affirmative symbol flashing me a problem with the path.
Here is the real scenario :
Our server is Linux and has a share on it :
\\192.168.3.49\CLIENTSHARE
The DLL is located here :
\\192.168.3.49\CLIENTSHARE\DLLS\dotnetdll.dll
Calling this directly makes the red-rounded affirmative symbol flash in the .net module tab of teststand indicating me that it has a problem but no pop-up message to tell what is failing.
Then I tried to map the network drive share to put aside the authentication process like this :
Y:\DLLS\dotnetdll.dll (with authentication already inside to avoid problems)
Still have the red-rounded affirmative symbol flash in the .net module tab of teststand indicating me that it has a problem but no pop-up message to tell what is failing.
I can't find any discussion on this issue and can't understand what I do wrong?
Why it would work locally and not remotly?
They call CVI DLLs from the same location without any problem.
Please help,
Eric
(4,542 Views)
Accepted by topic author ebonneau9
This was a total mistake!
The key in this problem is relative paths so I was way far from the solution at first.
After that, a configuration file with LoadRemoteSource tag set to true to enable full trust for loading DLL from remote folder.
And everything got up and running like a charm.
Hope this will help for someone else.
Eric
(4,532 Views)
