NI TestStand
C# TestStand API - "MainSequence" execution finishes immediately when using a process model
I am running the example sequence Computer Motherboard Test Sequence that comes with TestStand in a C# application using the TestStand API. I am trying to get a report out of it. If I run the MainSequence with no process model, everything seems to run okay. If I add in a process model, WaitForEndEx() returns right away and I don't see any popup from the sequence itself. I added a 5 second wait and a few message popups to the sequence and none of these appear to run. The ExecutionRunStates value shows that execution has stopped as well. My code is as follows:
Engine eng = new Engine();
User admin = eng.GetUser("administrator");
eng.CurrentUser = admin;
StationOptions stationOptions = eng.StationOptions;
stationOptions.DisableResults = false;
stationOptions.AllowOtherModels = true;
SequenceFile seqFile = eng.GetSequenceFileEx(seqName);
SequenceFile modFile = eng.GetSequenceFileEx("C:\\Program Files\\National Instruments\\TestStand 2017\\Components\\Models\\TestStandModels\\SequentialModel.seq");
Execution exec = eng.NewExecution(seqFile, "MainSequence", modFile, false, 0);
exec.WaitForEndEx(-1);
exec.GetStates(out ExecutionRunStates runState, out ExecutionTerminationStates termState); MessageBox.Show(runState.ToString()); MessageBox.Show(termState.ToString());
exec.Report.Save("report.xml", false, 0);
eng.ReleaseSequenceFileEx(seqFile); eng.ReleaseSequenceFileEx(modFile);
In the NewExecution() call, if I replace modFile with null, it runs as expected. If I change "MainSequence" to "Test UUTs" or "Single Pass", the code ends up stuck in WaitForEndEx(). I plan to focus on this more after I get "MainSequence" working correctly with a process model, but I figured I might as well bring it up in case anyone knows the solution to that.
(3,853 Views)
I may be wrong but it feels like you need to pass "Test UUTs" or "Single Pass" as your sequenceNameParam if you are using a model.  This is from the TestStand help:
sequenceNameParam As String
[In] Specifies the name of the sequence or Process Model entry point to execute.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,832 Views)
I was under the impression that I could do all three for the sequenceNameParam. If I use "Test UUTs" or "Single Pass" though, the application is forever in the WaitForEndEx(-1) call, so I must be missing something for those sequenceNameParam values as well.
(3,826 Views)
to be honest I've never really called a sequence file like this without a user interface or from an existing execution.  By user interface, I mean an executable that has an application manager.
Not sure if you know this but you can pass parameters to the shipping UIs and have it run silently.  https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9lvSAC
Generally I do this if I need to run a sequence file dynamically.
jigg
CTA, CLA
testeract.com
(3,818 Views)
Thanks for pointing me to that. That may be the route I need to go if I can get it working that way. Currently I'm trying to figure out how to get around the login screen and have it run silently.
(3,810 Views)
The way around the login dialog is to use a front end callback that simply sets the user to an administrator or operator.
jigg
CTA, CLA
testeract.com
(3,796 Views)
Accepted by topic author cjohnson963
I got it figured out. I should be using the "Single Pass" entry point and I had some non-standard results processing options set from going through the NI training on TestStand. I am now able to get the report and can use a process model.
(3,790 Views)
